Impedance calculation in piezoelectric device module
Hello all,
I am trying to plot the curve of the impedance Z in fuction of the frequency in piezoelectric device module.
I have succeeded to find the expression that sould be introduced to plot the admittance in the y axis. Nevertheless, introducing " imag(Y11.es) " plots the addmittance of the device considering that the damping is zedo (that's why he neglected the real part) which is not my case.
I will begrateful if someone can help with this. I just need the expression that shoud be introduced to calculate Z and arg(Z).
Regards
Hela
1 Reply Last Post 13 juin 2016, 12:30 UTC−4
Posted: 9 years ago 13 juin 2016, 12:30 UTC−4
Dear Hela,
I was wondering if you can help me with a problem. I am basically modeling a piezoelectric film that has a geometry of a square and I want to stretch it on both sides. Hence, I apply a boundary load and the rest is free. However, when I selected study, I got an error "
Failed to find a solution.
The relative error (4.6e+004) is greater than the relative tolerance.
Can you help me with this?
Dear Hela, I was wondering if you can help me with a problem. I am basically modeling a piezoelectric film that has a geometry of a square and I want to stretch it on both sides. Hence, I apply a boundary load and the rest is free. However, when I selected study, I got an error " Failed to find a solution. The relative error (4.6e+004) is greater than the relative tolerance. Returned solution is not converged. " Can you help me with this?
