Global Component To Calculate Capacitance Has Disappeared?
I am using the AC/DC electrostatics module to calculate the capacitance between two metal lines (a component of the overall detector I am modeling). I defined one of the lines as the terminal and another of the lines as ground using the boundary conditions, and applied a voltage. I have successfully obtained the capacitance between two objects before in COMSOL, but when I follow the same steps as I did last time by going to Global Evaluation (Component 1>Electrostatics>Terminals>es.C11 - Capacitance), es.C11 does not appear. Is there any reason why I am able to obtain capacitance this way in some models and not in others?
Thanks for any help.
2 Replies Last Post 15 avr. 2017, 17:54 UTC−4
Posted: 8 years ago 9 juin 2016, 16:00 UTC−4
Have you checked that the variable names has not just change a little in the newer version ?
Use the variable finder systematically it's quite easy, also often the CNTR-Space works for many entries.
Else you can turn on the Equation view and check the variable names there. I used the capacitance calculation last week so it is definitively there, but I'm not by my workstation just now ;)
Hi Have you checked that the variable names has not just change a little in the newer version ? Use the variable finder systematically it's quite easy, also often the CNTR-Space works for many entries. Else you can turn on the Equation view and check the variable names there. I used the capacitance calculation last week so it is definitively there, but I'm not by my workstation just now ;) -- Good luck Ivar
Posted: 8 years ago 15 avr. 2017, 17:54 UTC−4
Hi Ivar,
I have the same question on processing my model. Somehow I cannot get the any evaluated value by global evaluation in the way described in this topic. I need to obtain the capacitance for the model. Could you tell me how to do it in details?
Hi Ivar, I have the same question on processing my model. Somehow I cannot get the any evaluated value by global evaluation in the way described in this topic. I need to obtain the capacitance for the model. Could you tell me how to do it in details?
