Using COMSOL with Matlab Automation Server
I was trying to run COMSOL 3.5a with the matlab -automation option which would instead run a matlab automation server wiht COMSOL. To do this, I tried changing right-clicking the COMSOL 3.5a with MATLAB short-cut -> Properties and then changing the Target from
"C:\COMSOL35a\bin\comsol.exe matlab multiphysics"
to
C:\COMSOL35a\bin\comsol.exe matlab -automation multiphysics
I checked the COMSOL Operations and Installation guide and apparently there is no option for doing this.
If I do the same thing using a Matlab shortcut only, I can run the automation server. However, COMSOL requires the path to the root matlab executable file (ie not the shortcut so I can't just add the automation option there).
Was wondering if there was a workaround for this?
Thanks.
0 Replies Last Post 23 nov. 2010, 18:03 UTC−5
Hello Harsh Dhingra
