9 years ago
8 juin 2016, 02:06 UTC−4
Your current is too high compared to which value? Experimental one? What physic did you use? Electrostatics and you just gave the resistivity of the salt?
I do not know if this is relevant to you, but at the salt-electrode boundary an electrochemical reaction takes place which can be approximated with a resistor, obviously giving lower currents. I would take the Electrochemistry module (if you have access to it) and use Primary Current Distribution physics.
BR
Lasse
BR
Lasse
9 years ago
8 juin 2016, 03:08 UTC−4
Thank you for your reply! Answering your questions:
1) The total current (integrated over a boundary) is much higher (2 orders of magnitude) than the input current on the other side of the electrode. This is the biggest issue, I do not need to compare anything with experiment because current conservation law does not work here.
2) Physics I use: Electric currents (ec); study is: frequency domain
3) Yes, salt properties I put there.
As you suggested I will try electrochemistry module and use Primary Current Distribution physics.
Jeff Hiller
COMSOL Employee
9 years ago
8 juin 2016, 13:18 UTC−4
It is the integral of the normal component of the current density that is conserved, not the integral of the norm of the current density.
9 years ago
8 juin 2016, 16:13 UTC−4
Do you mean one should integrate ec.nJ instead of ec.normJ?
Well, in this case I get NaN.
See attached file. When you run it the "Table of values" will have the total current values obtained by integration along the boundary of each electrode. One is integrated over ec.normJ and gives 249A, the other is integrated over ec.normJ and gives NaN. The input current is only 10A.
I am definitely missing something.
[QUOTE]
[/QUOTE]
Jeff Hiller
COMSOL Employee
9 years ago
8 juin 2016, 17:21 UTC−4
If I may, you're trying to go about it a weird way!
See my modification of your file. I get within 2% of 10 amps on both boundaries, and you could refine your mesh to improve accuracy further if needed.
Note that you can't use ec.nJ on internal boundaries, hence my use of ec.Jx*nx+ec.Jy*ny+ec.Jz*nz . 3D Plot Group 6 shows you the direction of the normal vector on the boundaries in question (On external boundaries, n points outwards, but on internal boundaries you need to check visually).
See also
www.comsol.com/support/knowledgebase/973/ .
See also https://www.comsol.com/support/knowledgebase/973/ .
9 years ago
9 juin 2016, 02:50 UTC−4
Thanks for help!
Yeah, I should have read knowledgebase before jumping into this business...
Thanks for help!
