Inlet functions
For my job as a student assistant I shall create a vertical standing cylinder with a diameter of 2mm and a length of 2mm.
On top of the cylinder is a larger room that is filled with air.
The materials used in the simulation are water and air.
At the beginning of the experiment water is already present in the cylinder. In the course, due to its surface tension the water should form a hemisphere at the upper end of the cylinder.
The problem I have now is to fill the cylinder from the bottom up. The ideas I have for this are:
- Use the inlet:
o (constant) flow of water (velocity)
o Pressure function (Pressure, no viscous stress)
- Declare the bottom of the cylinder as “Moving wall” pressing the water out at the top similar to a syringe
Unfortunately, I did not manage any of the options listed so far.
I downloaded a model from the "Model Gallery" (Filling of a Capillary Channel; Model ID: 1878) and changed the geometry according to my task.
The forming of the hemisphere can be observed as well, but the achievement is not based on the methods mentioned above, but on the capillary effect.
Maybe someone has experience with something comparable or has dealt with a similar topic already.
With best regards
0 Replies Last Post 23 nov. 2010, 10:31 UTC−5
Hello René Ragge
