Matlab fatigue commands
I am doing a fatigue analysis (using matlab and 3.5a) currently using an lcf method. I am getting strange results, like one part the component failing before 1 cycle and other parts failing after 170,000,000 cycles!! The model is basically a very small cylinder bent in the shape of a half circle. I am wondering if these results are to do with the fact that the application is really an example of hcf and not lcf?
Can anyone tell me any commands that has a 'number of cycles output' for an hcf method?
Thanks in advance,
Chris
1 Reply Last Post 23 nov. 2010, 03:48 UTC−5
Posted: 1 decade ago 23 nov. 2010, 03:48 UTC−5
I should maybe point out that I am getting pretty much the same results regarless of the diameter of the cylinder, when keeping the length of it the same.
