Problems with STEP FUNCTION
Posted 18 mai 2016, 17:06 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Materials, Studies & Solvers Version 5.2 2 Replies
Hi everybody,
I have an inlet in a water reactor working in the following way: 10 s on, 80 s off, 10 s on, 80 s off....
-Fist of all, I have built a PIECEWISE (pw1) function (0<t<10 = 1, 10<t<90 = 0)
-Then, using this piecewise function I have built an ANALYTIC function (an1) with a periodic extension 0-90, and plot parameters 0-900. When I plot it, everything is OK.
- Finally I have created a variable for the inlet velocity: 0.265[m/s]*an1(t[1/s])
When I compute my model, the inlet works only in the first 10 seconds, but after 90 seconds it doesn´t start working agains as an inlet, there is no velocity.
Why????
Thank you so much
Why????
Thank you so much
2 Replies Last Post 20 mai 2016, 11:00 UTC−4
