how to set BC on 3D point on sphere surface to V=0
I can do this in CSv3.5, but cannot find how to with v4. My initial toy problem is a single solid sphere with 3 points defined on its surface. One point is a positive current source, one is a matching negative source (sink), and the third point needs to be set to V=0. I can actually set the current sources up properly, but cannot find where to set the BC I need on the third point.
1 Reply Last Post 14 nov. 2010, 02:27 UTC−5
Posted: 1 decade ago 14 nov. 2010, 02:27 UTC−5
it would be far easier for us to understand your issue if you told us at least the verson and physics, You have the topic selection below, but just a [4.0a/MEF] or something like that could do too
If I understand you are looking for a fixed potential BC, so I believe that depends on the physics you have choosen, are you sure it resolves the voltage ?
Hi it would be far easier for us to understand your issue if you told us at least the verson and physics, You have the topic selection below, but just a [4.0a/MEF] or something like that could do too If I understand you are looking for a fixed potential BC, so I believe that depends on the physics you have choosen, are you sure it resolves the voltage ? -- Good luck Ivar
