Reproducing a 'Floating Potential' via weak constraints
Posted 4 mai 2016, 08:34 UTC−4 Version 5.2 1 Reply
In order to understand weak constraints (to be used in a more complicated problem), I am trying to reproduce a 'Floating Potential' node (in electrostatics) by weak constraints.
To go systematically, I did the following in the attached model:
CASE 1: Electric Potential
I have set a fixed potential on the test electrode (left circle), -1V. I made a global evaluation to calculate the charge: intop1(nx*up(es.Dx)+ny*up(es.Dy)) - the integral on the electrode surface gives the charge, which resulted in -2.4152e-11 C/m
CASE 2: Floating potential
(Electric Potential disabled). I have specified a floating potential on the same electrode, and plugged in the value -2.4152e-11 C/m from the previous calculation. I get the same pattern
CASE 3: (Floating potential disabled)
- Global constraint: intop1(nx*up(es.Dx)+ny*up(es.Dy))+2.4152e-11[C/m], which is supposed to set the total charge of the electrode
- Weak constraint: nx*up(es.Ey)-ny*up(es.Ex), which is the cross product between the normal vector of the surface and E. This constraint prescribes that E is normal to the surface (i.e. no tangential component, the electrode surfaces is on isopotential).
The field pattern I get is completely different.
I am trying to read more about weak constraints and understand it better. It will go faster if somebody gives a smart hint.
From the 'Floating potential' node I deduced that it works by setting a constraint on V at the boundary (to some floating value), rather than requiring E to have a vanishing tangential component. How would this be done in a weak constraint node?
Thank you
Thank you
1 Reply Last Post 4 mai 2016, 09:49 UTC−4
