radiation in 2d cable
Stefanos Kinigopoulos
i am working on my diploma thesis in which I must simulate a 2D cable and get the temperature charts in various cases such as emission (radiation) from the cable to ambient and radiation from ambient (sun) to the cable. And I am stuck due to some (simple for you) problems:
1) i chose the "heat in transfer in solids" model and added "diffuse surface". I chose the outer surface of the cable as the diffuse surface boundary and selected a surface emissivity (0.8). When I compute at a stationary study the results are wrong. They are -600 K at both the surface and the inner of the cable. When I try a time depended study the results are ok. Do you have any idea how to solve that? or why does this happen?
2) how do you simulate radiation from an external source (sun) to the cable in 2d? I tried the "heat transfer with surface to surface radiation module but it didn't work.
I am sorry for my English and the big questions!
Thank you in advance for you help!
1 Reply Last Post 12 juin 2016, 05:29 UTC−4
Hello Stefanos Kinigopoulos
Posted: 8 years ago 12 juin 2016, 05:29 UTC−4
Dear Sir,
please let me know how you work to get the temperature ?
did you apply current source on conductor or you assume the final temperature on surface of conductor on max. load current ?
the easily way is to fix temperature at the surface of the conductor and let it work
try to attache your model to check with you the problem
thanks
MSM
Dear Sir, please let me know how you work to get the temperature ? did you apply current source on conductor or you assume the final temperature on surface of conductor on max. load current ? the easily way is to fix temperature at the surface of the conductor and let it work try to attache your model to check with you the problem thanks -- MSM
