Error: Failed to find time step so that given tolerances are satisfied.
Posted 31 oct. 2010, 17:02 UTC−4 2 Replies
Hello Everybody,
I'm using a 2D structural mechanics module.
The geometry is a simple square.
The material is Viscoelastic.
I applied boundary conditions on the square.
I chose the Time Dependent solver --> Quasi-static transient.
The boundary conditions I defined are dependent on a new parameter.
I defined this new parameter as a function of the timestep (as a function of time...).
As a result I received the following error:
Error: time 0:
... I tried changing the time steps and the tolerances - but no luck there!
Does anyone have an idea?
I would very much appreciate your help!
Thank you :)
Tal
Error: time 0:
Thank you :)
Tal
2 Replies Last Post 13 mars 2012, 17:14 UTC−4
