Maximum value of a parameter over a certain range of temperature
Posted 17 mars 2016, 08:20 UTC+1 0 Replies
I have developed a simple 1D time dependant solidification model (Heat Transfer with Phase Change module), and am facing a problem:
I have introduced a new variable V1 that varies locally when the temperature T change. I need to evaluate the maximum of this variable V1, at different positions, and over a specific range of temperature. An exemple would be: what is max(V1, T) at x=0.01, and between T=1800K and T=1900K.
It is no problem to assign a position, but I am stuck when it comes to assigning a specific range of temperature... Does anybody know how to do that? Is there an operator that can do the job?
Thank you!!
Antoine
Hello Antoine Autruffe
