Error Index:2, Size 2, Feature: Stationary Solver 1
I have a Frequency Domain study looking at the dynamic response of an un-deformed structure immersed in water. I am using Solid Mechanics, Pressure Acoustics - Frequency Domain (acpr) and Multi-physics defined in the model. This is a problem type I have solved many times (recently upgraded to v5.2).
Initially looking to solve the model at zero pressure (un-deformed) but I unfortunately get an error message "Index: 2, Size: 2" and despite looking through the model numerous times, resetting to defaults etc. I can not resolve this!
Can anyone help give an indication of what this error may relate to ...its so brief its unhelpful!
Unfortunately I am unable to share the model - sorry
Thanks in advance Colin
2 Replies Last Post 15 mars 2016, 12:31 UTC−4
Posted: 9 years ago 15 mars 2016, 12:16 UTC−4
Apologies forgot to say I was still using v5.1.
Just opened the model in v5.2 and the study has run without a problem!
Colin
Apologies forgot to say I was still using v5.1. Just opened the model in v5.2 and the study has run without a problem! Colin
Posted: 9 years ago 15 mars 2016, 12:31 UTC−4
Just in case you were wondering if it was the fact that the model file had been saved and re-opened rather than using v5.2 ...no it wasn't ...I still get the error in v5.1.
Recommendation: with this error use v5.2
Colin
Hi Just in case you were wondering if it was the fact that the model file had been saved and re-opened rather than using v5.2 ...no it wasn't ...I still get the error in v5.1. Recommendation: with this error use v5.2 Colin
