Error: 9040 Fatal error. - Type: IllegalArgumentException
Posted 26 oct. 2010, 14:45 UTC−4 1 Reply
I am working with COMSOL multiphysics 3.4 in windows 7. I am running into the error below when ever I try to mesh a model, even a simple 2D rectangle. If anyone has encounter this issue before and found a resolution or has an idea for a resolution I would appreciate it. Thanks.
Error: 9040
Fatal error.
Exception:
java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice
(rethrown as com.femlab.util.FlFatalException)
Fatal error.
Stack trace:
at java.awt.Component.checkGD(Unknown Source)
at java.awt.Container.checkGD(Unknown Source)
at java.awt.Container.addImpl(Unknown Source)
at java.awt.Container.add(Unknown Source)
at com.femlab.gui.MainPanel.a(Unknown Source)
at com.femlab.gui.GuiMode.a(Unknown Source)
at com.femlab.gui.GuiMode.c(Unknown Source)
at com.femlab.gui.MeshMode.a(Unknown Source)
at com.femlab.gui.GuiMode.j(Unknown Source)
at com.femlab.gui.au.a(Unknown Source)
at com.femlab.gui.au.b(Unknown Source)
at com.femlab.gui.b.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.femlab.gui.e.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at com.femlab.controls.FlDialog.showAsDialog(Unknown Source)
at com.femlab.controls.FlDialog.show(Unknown Source)
at com.femlab.controls.FlModalDialog.show(Unknown Source)
at com.femlab.controls.FlDialog.showDialog(Unknown Source)
at com.femlab.gui.dialogs.z.run(Unknown Source)
at com.femlab.util.ab.run(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Error: 9040
Fatal error.
Exception:
Fatal error.
Stack trace:
1 Reply Last Post 26 oct. 2010, 15:03 UTC−4
