to create hole in a thin film
I am facing problem to make holes in a thin film. I made a thin film using 'block' in geometry. Now I need to create holes of rectangular shapes in this film.
Kal
2 Replies Last Post 5 mars 2016, 08:13 UTC+1
Posted: 9 years ago 3 mars 2016, 13:49 UTC+1
Make a 2D geometry with rectangular holes and then extrude (you can find this in work plane) that to required depth of the film.
Suresh
Hi, Make a 2D geometry with rectangular holes and then extrude (you can find this in work plane) that to required depth of the film. Suresh
Posted: 9 years ago 5 mars 2016, 08:13 UTC+1
I have made a hole in a silver metal film. Holes are periodic in the metal film. I have applied floquet bounday conditions. but I don't know what's the problem , I have tried all kind of meshing as well but still the simulation shows error.
Suresh
[QUOTE] Hi I have made a hole in a silver metal film. Holes are periodic in the metal film. I have applied floquet bounday conditions. but I don't know what's the problem , I have tried all kind of meshing as well but still the simulation shows error. Hi, Make a 2D geometry with rectangular holes and then extrude (you can find this in work plane) that to required depth of the film. Suresh [/QUOTE]
