3-D Maximum displacement
Hi all,
I have try out with 3-D, stress-strain MEMS model in order to find maximum displacement of membrane deflection with uniform force exert on it. Does anyone know how to display the maximum displacement value?
Issit the max/min marker will display the maximum displacement?
1 Reply Last Post 21 oct. 2010, 01:48 UTC−4
Posted: 1 decade ago 21 oct. 2010, 01:48 UTC−4
Yes there are, but it depends in which version you are working in V4 there are several operators or probe possibilities. However in v3.5 you might have to use the matlab interface. This has been discussed a few imes, I even believe there is a small matlab code example in a previous thread, try a search on the forum. There are many nice things here
Hi Yes there are, but it depends in which version you are working in V4 there are several operators or probe possibilities. However in v3.5 you might have to use the matlab interface. This has been discussed a few imes, I even believe there is a small matlab code example in a previous thread, try a search on the forum. There are many nice things here -- Good luck Ivar
