Comsol in Matlab
Posted 19 oct. 2010, 09:19 UTC−4 3 Replies
Hi All,
I am new to comsol and am trying to use it to simulate a diffusion based system with adsorption.
I have managed to do this for a single geometry (a geometry of a 2d plane with holes removed) but i would like to be able to generate a random placement of the holes, and perform the calculation multiple times. This seems like a problem best tackled using comsol in matlab, as loops are easily implemented in matlab, and it is easy to generate random geometry.
I am having a problem running comsol in matlab. Using the command "comsol40a server matlab" opens matlab with a comsol server. However when I run one of the library models i recieve the following output
ans =
Type: Root
Tag: Model
Identifier: root
Having viewed the output in the GUI in comsol I cannot see the results in matlab.
In addition to this, when using other models that I have created, which work in comsol, I occasionally get stack trace erros and java exception errors.
This may be a trivial error but I am very new to both comsol and matlab. I am using comsol version40a and matlab 2010b
ans =
Type: Root
Tag: Model
Identifier: root
3 Replies Last Post 19 oct. 2010, 11:38 UTC−4
