Vectors with random orientation
Hey guys,
I'm interested to generate random vectors for the initial condition of my 3D model which is basically for solving time-dependent PDEs. The problem is the components of these vectors are random but sum of squares (which is the magnitude of the vectors) should be constant. In other words, I need to generate vectors with same magnitude but with random orientations. So the question is if I can do this in COMSOL using built in random function or any other ways without going through the hassle of using MATLAB.
8 Replies Last Post 16 août 2016, 21:23 UTC−4
Posted: 9 years ago 21 févr. 2016, 10:53 UTC−5
Hello? Can somebody help?
Posted: 9 years ago 23 févr. 2016, 09:29 UTC−5
I guess I found how to do this. You need to generate three random numbers using the random function in COMSOL. Let's say these numbers are a, b, and c. Using the expression bellow you can generate components of unit vectors with random orientations. Multiply them with the magnitude of your desired vector and you get vectors with same magnitude but random orientations.
a'=a/sqrt(a^2+b^2+c^2)
b'=b/sqrt(a^2+b^2+c^2)
c'=c/sqrt(a^2+b^2+c^2)
I guess I found how to do this. You need to generate three random numbers using the random function in COMSOL. Let's say these numbers are a, b, and c. Using the expression bellow you can generate components of unit vectors with random orientations. Multiply them with the magnitude of your desired vector and you get vectors with same magnitude but random orientations. a'=a/sqrt(a^2+b^2+c^2) b'=b/sqrt(a^2+b^2+c^2) c'=c/sqrt(a^2+b^2+c^2)
Posted: 9 years ago 24 févr. 2016, 02:12 UTC−5
This is a decent approximation, but you don't get a uniform distribution over set of directions.
Posted: 9 years ago 2 mars 2016, 15:42 UTC−5
Do you know any alternatives?
[QUOTE] This is a decent approximation, but you don't get a uniform distribution over set of directions. [/QUOTE] Do you know any alternatives?
Posted: 9 years ago 3 mars 2016, 02:31 UTC−5
For a mathematical question such as yours I think that Google is a faster way to find an answer than this forum: Search for e.g. "random vector sphere".
[QUOTE]Do you know any alternatives?[/QUOTE] For a mathematical question such as yours I think that Google is a faster way to find an answer than this forum: Search for e.g. "random vector sphere".
Posted: 9 years ago 16 août 2016, 11:48 UTC−4
I'm having the same problem. So, let me give it a try.
Let's say the magnitude of the vector is equal to N and the direction of the vector varies with time.
For 2D simulation, I think one can create a random function (named rn1) with uniform distribution that ranges from -pi to pi (or 0 to 2*pi). By doing so, the x-compnent and y-compoent of the vector correspond to N*cos(rn1(t)) and N*sin(rn1(t)).
As for 3D simulation, I think it is just in analogy to spherical coordinate. If one creates two random functions both ranging from -pi to pi, then
x-component: N*sin(rn1(t))*cos(rn2(t))
y-component: N*sin(rn1(t))*sin(rn2(t))
z-component: N*cos(rn1(t))
Am I right about this?
I'm having the same problem. So, let me give it a try. Let's say the magnitude of the vector is equal to N and the direction of the vector varies with time. For 2D simulation, I think one can create a random function (named rn1) with uniform distribution that ranges from -pi to pi (or 0 to 2*pi). By doing so, the x-compnent and y-compoent of the vector correspond to N*cos(rn1(t)) and N*sin(rn1(t)). As for 3D simulation, I think it is just in analogy to spherical coordinate. If one creates two random functions both ranging from -pi to pi, then x-component: N*sin(rn1(t))*cos(rn2(t)) y-component: N*sin(rn1(t))*sin(rn2(t)) z-component: N*cos(rn1(t)) Am I right about this?
Posted: 9 years ago 16 août 2016, 16:47 UTC−4
No, that's not correct. Things are different on a sphere!
Being curious I followed Gunnar's advice and in less than a minute I found: mathworld.wolfram.com/SpherePointPicking.html
wolfram.com is frequently a very good resource for mathematics.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
No, that's not correct. Things are different on a sphere! Being curious I followed Gunnar's advice and in less than a minute I found: http://mathworld.wolfram.com/SpherePointPicking.html wolfram.com is frequently a very good resource for mathematics. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 9 years ago 16 août 2016, 21:23 UTC−4
Hi Edgar,
Thanks for your reply. I finally know how to solve problem correctly.
Hi Edgar, Thanks for your reply. I finally know how to solve problem correctly.
