Piecewise function to define material property
Posted 15 févr. 2016, 10:12 UTC−5 Materials Version 4.4, Version 5.0, Version 5.1 2 Replies
Hi All,
I would like to define a material with thermal conductivity (k) that is dependent on both temperature (T) and the absolute pressure (pA) using piecewise function. I know that COMSOL has default models for k that is T dependent only -such as for Nitrogen defined within the 200 - 1200 K range.
How is the syntax -if possible to employ two parameters in the same piecewise function ? I tried separating them using comma and space but did not work.
-Ozan
-Ozan
2 Replies Last Post 16 févr. 2016, 02:00 UTC−5
