Coil Group Box under Multi-Turn Coil
Posted 12 févr. 2016, 16:26 UTC−5 Low-Frequency Electromagnetics, Studies & Solvers Version 5.2 1 Reply
In axial-symmetric geometry I am simulating magnetic fields created from multiple multi-layer solenoids stacked on top of each other.
I am using the Multi-Turn Coil function, and had a question regarding the number of turns applied when checking the Coil Group Box.
Let's say I have the box checked, and I have 100 turns as my value for N. If I select 2 domains, will it simulate 100 coils in each domain or will it split the number in half?
Thank you!
Thank you!
1 Reply Last Post 14 févr. 2016, 14:23 UTC−5
