Hello Jakub Zlamal
24 févr. 2011, 09:29 UTC−5
I have the same problem: I'm trying to set a breakpoint in a Matlab functiona that is being called by Comsol for debugging purposes.
any Idea on how to do that?
24 févr. 2011, 10:23 UTC−5
It is not possible to debug MATLAB function. (Only possibility is to write debug information in matlab function to file and look at it).
If You change function You must restart comsol to take changes into account or use clearfunction in MATLAB prompt
5 nov. 2012, 10:36 UTC−5
My (dirty) solution:
function C = add(a,b)
fid = fopen('/home/user/log','w');
fprintf(fid,'display your debug log\n');
fclose(fid)
end
I use a file as debug log. It works but it's not an ideal solution...
fclose(fid)
end
Remi Magnard
COMSOL Employee
7 nov. 2012, 04:52 UTC−5
If you are running COMSOL on Windows you can benefit of the MATLAB debugger.
What you need to do is:
1- Evaluate first the function so that a MATLAB process is started, for instance use the plot button in the function settings tab.
2- At the MATLAB prompt, that should have poped-up automatically to evaluate the function, type: desktop
3- You can now edit the function and add break point.
4- When running the model,the MATLAB debugger automatically stops at the break point and you can verify the intermediate value of the function variables.
This is also described in the LiveLink for MATLAB User's guide: Calling MATLAB function > The MATLAB Function Feature Node > Using the MATLAB Debugger (Windows only), (page 185 in the COMSOL 4.3a documentation)
Enjoy the modeling !
9 years ago
20 avr. 2016, 14:33 UTC−4
I've been searching for a solution to this problem as well. I followed the instructions provided, but when I click 'compute' to run my Comsol model, all of my breakpoints disappear in my matlab functions. Do I need to pass any sort of flag when I type desktop, that enables debugging? Or is this some sort of glitch?
For reference, I am using version 5.1
9 years ago
20 avr. 2016, 18:07 UTC−4
In case anyone else is having problems, I discovered that if you have 'Clear functions automatically before solving' selected for your Matlab function, it resets all the breakpoints in that function prior to running. This box is useful if you have made any changes to your function since Comsol last used it, but is unnecessary otherwise. If this box is unchecked, you can proceed with debugging.
