Disabling Java security manager on linux?
Posted 3 févr. 2016, 10:41 UTC−5 1 Reply
I want to use my Java code under linux, that worked before under Windows. It seems that the Java security manager disables many things, among others creating any files. Running the code below from the command line (java -cp . test) produces the file in my home directory. When I run it from comsol, I get the message
access denied ("java.io.FilePermission" "/home/barna/comsol.test.out" "write")
How can I disable the security manager in comsol? (I am using comsmol 5.1)
Thank you
daniel
import com.comsol.model.*;
import com.comsol.model.util.*;
import java.io.*;
public class test
public static void main(String[] args) throws Throwable
try
PrintWriter pw = new PrintWriter("/home/barna/comsol.test.out");
pw.printf("Hello world\n");
pw.close();
catch(SecurityException t)
Message.show(t.getMessage());
Thank you
daniel
import java.io.*;
public class test
try
pw.close();
1 Reply Last Post 8 févr. 2016, 05:02 UTC−5
