How can I import field results from other solver into COMSOL?
Posted 11 août 2010, 08:29 UTC−4 0 Replies
I build up the same model with same geometry and position in COMSOL. I want to use COMSOL for further simulation, like temperature distribution using heat transfer module. How can I import the resistive power field result into COMSOL for further simulation in COMSOL?
I assume there are 2 major problems.
1. How to mesh the structure exactly the same with the mesh i used in the other solver (software)?
2. How to import the field result point by point into COMSOL?
I'm using COMSOL 3.4 currently by the way.
Hello Liang Cheng
