Robert Koslover
Certified Consultant
12 juil. 2012, 13:14 UTC−4
I can't speak to the details of your particular model, but typically, Comsol Multiphysics will let you specify all the relevant boundary conditions. So if, for example, continuity of the normal component of electric field across a boundary is an appropriate specification, then the software will generally enforce it already or allow you to do so. Suppose, for example, that your boundary were simply a continuity condition (such as a non-physical "surface" in the middle of a problem, due to the way you built the geometry). In that case, both normal and tangential fields would automatically be continuous across it, without you having to specify that condition at all. On the other hand, if a surface were the surface of a conductor or dielectric, it would generally be a mistake to tell the software to enforce continuity of the normal component of E since, in fact, the normal component is generally discontinuous there due to the surface charge density. If this explanation doesn't help, you may need to explain in more detail the nature of your specific problem & model, so that people reading this can figure out where the issue is.
16 juil. 2012, 21:33 UTC−4
Hi Robert,
Thank you for your response.
I have overcome this problem.
Hi Robert,
