21 sept. 2010, 01:13 UTC−4
I understand this as the displacement = sqrt(u^2+v^...) is not defined for your domain/boundaries. Could it be that you did not select it in the model definitons ? or that some matgerial constant is not complete or not applied to all boundaries ?
22 sept. 2010, 12:49 UTC−4
Hi Ivar,
I reduce the three plate model to a single plate and fix all the boundaries except the top surface for which I check the prescribed displacement in all the x, y and z directions. However, I still get the same error for the top surface of the single plate. Any suggestions or ideas?
Hi Ivar,
22 sept. 2010, 13:01 UTC−4
Also, in warnings it says not all domains are meshed. But I do Mapped meshing for the entire geometry and selecte build selected. So I do not understand how are my domains not meshed.
22 sept. 2010, 14:46 UTC−4
I have been burned a couple of times with someting similar, I had meshed all boundaries but not the volume/domain Could that be your case (rather easy in v3.5) probably not possible in V4 (to be checked)
Have you tried to use the "select remaining" in the mesh environment ? if something is selected then not everything is meshed.
27 sept. 2010, 03:22 UTC−4
In comsol, when you use mapped meshing, it meshes the boundary only no the domain. So your model indeed has no solid mesh. Use Free Tetrahedral or Swept option instead.
3 oct. 2010, 16:06 UTC−4
Yes, when I use the treatrahedral mesh the problem goes away.
9 nov. 2013, 17:46 UTC−5
Hi Piyush,
I'm currently working on a project at UIUC. I read about your paper and was trying to use Comsol to create thermal stress between two layered plates. I was wondering if you could help me out. I have run into the message that says I have undefined value. I don't understand what it's referring to. What were the major steps you used in creating your models?
Many thanks in advance for any help!
PS. I've attached my file to this email
Arthur
Hi Piyush,
Arthur
