9 years ago
18 nov. 2015, 02:44 UTC−5
first of all there are a few BC I do not understand in your model:
1) the body load on the solid and the Volume force have different sign, that's probably a typo, it also applies to the initial strain, why should it be diagonal identical like that ? I would start without your initial Strain case and check its form, or use a stationary case to "preload" the material
2) you fix with prescribed mesh displacement the fluid, that is not really required as you are on the axial symmetry, anyhow I would not prescribe the "z" direction, OK for the "r"
3) Roller condition is like a symmetry condition, since you are in 2D-axi the axis remains as is, therefore the right roller is probably not required but probably that far away it does not influence a lot
4) you have selected the nearly incompressible material, but your nu is 0.25, normally one uses the additional "p" variable for materials with nu>0.49. it makes the calculations longer, but probably does not make anything wrong, you can get a "p" plot also in the solid like that
Then some general comments:
a) your solid is very "large" compared to the fluid, it just makes the model rather big and heavy, but OK it solves on my laptop, not critical
b) you could probably work quicker by using Stockes flow (neglecting the inertia terms), this makes the time dependent solver work quickly as you will not see any sound wave transients
9 years ago
18 nov. 2015, 11:02 UTC−5
Hi Ivar,
Thank you very much for your reply. I have taken your advice into account.
Regarding 1), the initial stress is to reproduce the initial lithostatic crustal stress. It has been validated in several solid mechanics-only models. It should be equivalent to your solution of preloading it by first running the stationnay solution (I will check that).
I am still not understanding how the volume force works.. On the figure attached, you can see the fluid pressure when just subjected to the applied volume force of - rho * g , not any other force, and just solving for the fluid part. I am not understanding the sign and magnitude of it, which are not equivalent to -rho*g*z.
Helene
Hi Ivar,
Helene
9 years ago
18 nov. 2015, 16:43 UTC−5
I was a bit too quick with some of my comments I see:
Volume force is the force applied to "dx*dy*dz[m^3]" hence it's "spf.rho*g_const[N/m^3]". Formally its the product of both that gives you the force, and total force once integrated over the full domain(s).
Now gravity is mostly defined along "-z" hence the traditional minus sign for Volume Forces, to add to the formula above.
Now, for the initial condition it is different.
This depends where you set the gauge pressure p=0[Pa] level. So if your fluid is just above z>=0 then the initial condition (again applied to the element volume "dx*dy*dz") is "-spf.rho*g_const*z".
The means that the pressure would be p(z=0)=0[Pa] and it will be relative with a negative sign above z=0.
If you try to solve fluids alone and set the initial condition correctly your model might not converge fully, but still it should give a correct pressure value.
Then for the initial stress tensor, the diagonal elements should not be all equal from my understanding, the two first OK are isotropic in R & Phi, but the Z component should be greater. Here again one need to define the "zero gauge Z level", so if gravity is along -Z the diagonal elements should be from my understanding: "-g_const*solid.rho*( nu/(1-nu) , nu/(1-nu) , 1)*z" all in [Pa]. with Z=0 at top level of the solid.
