I can´t select the diaphragm to visualize the displacement in the Capacitive Pressure Sensor
After "Compute" there isn't any problem but I can't make the individual visualization of the diaphragm as the procedure indicates because the Selection button in the Results toolbar is not available (is like transparent). Somebody knows how to fix that? Thanks.
2 Replies Last Post 24 juin 2016, 16:33 UTC−4
Hello Myriam Paredes
Posted: 8 years ago 24 juin 2016, 16:17 UTC−4
could you have solution this problem? that happened to me
Posted: 8 years ago 24 juin 2016, 16:33 UTC−4
A data set needs to be selected for the Selection button to be active.
A data set needs to be selected for the Selection button to be active. Best, Jeff
