Importing parameterized geometries?
Hey Guys,
I'd like to import geometries used in a previous model which are partly defined with parameters (certain distances, lengths, radii). Is it possible to import an existing geometry into COMSOL without just having the "import"-bracket? I'd need to do some parametric sweeps afterwards and in that case I'd have to build a new model for that.
5 Replies Last Post 4 mai 2017, 20:28 UTC−4
Posted: 9 years ago 24 sept. 2015, 08:27 UTC−4
I am not sure I understand what you mean by "without just having the "import"-bracket ", but from the rest of your post it seems that you can use Insert Sequence.
I am not sure I understand what you mean by "without just having the "import"-bracket ", but from the rest of your post it seems that you can use Insert Sequence. Best regards, Jeff
Posted: 9 years ago 24 sept. 2015, 08:39 UTC−4
Hi Jeff,
that's actually what I mean. But how do I export a sequence? Haven't found the button for that, yet :/ .
Hi Jeff, that's actually what I mean. But how do I export a sequence? Haven't found the button for that, yet :/ .
Posted: 9 years ago 24 sept. 2015, 09:54 UTC−4
You don't need to export a sequence out of the old file (the one that contains the geometric sequence you want to pass to a new file).
In the new file (the one into which you want to insert the sequence), you add an Insert Sequence node and in that node's settings you point to the old .mph file.
That's it.
In the new file, you'll notice that COMSOL brings in all the geometry parameters for you.
You don't need to export a sequence out of the old file (the one that contains the geometric sequence you want to pass to a new file). In the new file (the one into which you want to insert the sequence), you add an Insert Sequence node and in that node's settings you point to the old .mph file. That's it. In the new file, you'll notice that COMSOL brings in all the geometry parameters for you. Jeff
Posted: 9 years ago 25 sept. 2015, 02:31 UTC−4
Thank you so much!
That made it and it's amazingly easy :). That will make further projects much easier.
Have a nice weekend,
Philipp. :-)
Thank you so much! That made it and it's amazingly easy :). That will make further projects much easier. Have a nice weekend, Philipp. :-)
Posted: 7 years ago 4 mai 2017, 20:28 UTC−4
Is it possible to convert a Comsol imported geometry (or the geometry file itself- mphbin) to the original sequence without having the original simulation? Deleted it by mistake.
