[Porous Media] Brinkman and Heat Transfer in porous media: how can I create a coupling?
Dear all,
I am a trying to simulate an aluminum foam radiator using COMSOL 5.1 Update 2. I have some trubles understanding how the multi psychics works.
I am using a 2D approach in the beginning. I set all the foam and fluid characteristics and I am able to run a study using only the the Brinkman equation and I get good results. I am simulating a basic and simple situation (uncompressible and laminar flow, steady study, ).
I would like to understand how I can couple the results of the Brinkman study (velocity and pressure) with the Heat Transfer Module. I am not sure abut how to do this. Reading the Heat Transfer User Guide, pag 76 "Model Input Based Coupling", I can understand that, in case of laminar flow, I can create a coupling based on the model input. Is this correct? Or should I use a non-isothermal flow multiphysics coupling?
I could I define the velocity and pressure inputs in the heat transfer interface (I set both of them to br so they are taken from the Brinkman interface).
Now, unfortunately, I can't understand how can I define the temperature model input in the flow interface. Can you help me?
Thanks!
3 Replies Last Post 8 mars 2017, 16:11 UTC−5
Hello Vittorio Villani
Tupakula Rama Krishna
Posted: 8 years ago 1 mars 2017, 01:09 UTC−5
Hoping u might overcome this problem by now, can u pls share ur files with us
Posted: 8 years ago 8 mars 2017, 16:11 UTC−5
I am having similar trouble with imposing boundary conditions but for mass transfer. Could you share your files if you figured out how to couple the two physics?
Hi I am having similar trouble with imposing boundary conditions but for mass transfer. Could you share your files if you figured out how to couple the two physics?
I am having similar trouble with imposing boundary conditions but for mass transfer. Were you able to obtain the solution files for your problem? Could you share your files if you figured out how to couple the two physics?
Hi I am having similar trouble with imposing boundary conditions but for mass transfer. Were you able to obtain the solution files for your problem? Could you share your files if you figured out how to couple the two physics?
