1 Reply Last Post 21 sept. 2009, 12:27 UTC−4
Posted: 2 decades ago 21 sept. 2009, 12:27 UTC−4
That's what "frequency response analysis" is for, it assumes harmonic excitation at frequency "freq_" (complete with the _... your application mode shortcut). Use the parameter fonctionality to sweep over frequency. Take a closer read through the specific documentation, you will find most replies therein
Hi That's what "frequency response analysis" is for, it assumes harmonic excitation at frequency "freq_" (complete with the _... your application mode shortcut). Use the parameter fonctionality to sweep over frequency. Take a closer read through the specific documentation, you will find most replies therein Good luck Ivar
