temperature change along varying heat capacity
Posted 3 juin 2015, 10:02 UTC−4 Materials Version 4.4 0 Replies
I was analyzing a heat transfer in solids.
I used power dissipation model to increase temperature for alumina.
used stationary study.
when I analyzed the simulation, I wonder that why varying heat capacity does not affect temperature change.
I found a different material properties not pure alumina. So, I changed heat capacity, but there is no temperature change. I can not understand that the temperature of material that same energy was losing in the material which has a different heat capacity was not changed.
The heat capacity was changed, but there was no temperature change with same condition except heat capacity. Then the material properties was not applied in COMSOL or not? or different problem?
If there is somebody to know, please teach me about this problem,!
thank you,!
Hello MinKi Kim
