How to add inertial lift force, dean forces in particle tracing module?
I'm working on a curved microfluidic channel and trying to use it to separate two particles.
However, when I use the particle tracing module, I could not find where to add the interial lift force and dean forces.
Could anyone help?
Thank you in advance!
Cecelia
2 Replies Last Post 29 nov. 2016, 20:39 UTC−5
Hello Zheng Dai
Posted: 9 years ago 6 oct. 2015, 05:41 UTC−4
I m also facing the same problem. Did you got any solution for this. I tried to add them in particle tracing-> Forces -> expressions for lift forces. Still no use.
Looking for anybody who can suggest some good idea.
Hi, I m also facing the same problem. Did you got any solution for this. I tried to add them in particle tracing-> Forces -> expressions for lift forces. Still no use. Looking for anybody who can suggest some good idea. Thanks
Posted: 8 years ago 29 nov. 2016, 20:39 UTC−5
Hi Usuf,
I have the same problem that I could not add inertial lift force and Dean force. I tried inputting lateral
force but it seemed no use. And I still wonder how to figure out adding the Dean force.
Have you figured it out? I wish we could discuss on this.
Regards
Joel
Hi Usuf, I have the same problem that I could not add inertial lift force and Dean force. I tried inputting lateral force but it seemed no use. And I still wonder how to figure out adding the Dean force. Have you figured it out? I wish we could discuss on this. Regards Joel
