How to change color gradient on thermal map?
Posted 20 mai 2015, 16:57 UTC−4 Heat Transfer & Phase Change, Microfluidics, Results & Visualization Version 4.4 0 Replies
OR is there a way to re-do the thermal map (white to red) for the box that I select?
ALSO are there more ways to view the thermal map other than the temperature map and the isothermal contours?
Thanks in advance.
Hello Eun Jin Cho
