Reading simulation results through VBA code in excel
Posted 4 mai 2015, 08:00 UTC−4 Version 5.0 0 Replies
I am trying to extract the results of a COMSOL optimization through VBA code in Excel with no luck. To my knowledge the simulation runs but i can't access the results. I am new both to VBA and Livelink but I expected the procedure to be straight forward which unfortunately it is not. I want to read the optimized parameter as well as a few other probe values that are in the component definitions and are evaluated in the study, back into Excel. The relevant VBA code is this:
'Get data from Excel cells
Iact = Sheets("Data_acc.geom").Range("B" & ActiveCell.Row).Value / 1000
Disp = Sheets("Data_acc.geom").Range("F" & ActiveCell.Row).Value / 1000000000
'Set data to COMSOL parameters and run the optimization study
Call model.param.set("Iact", Str(Iact))
Call model.param.set("Disp_target", Str(Disp))
Call modelutil.ShowProgress(True)
Call model.get_study("std7").Run
'Extract results <- problem here
Set res_CTE = model.result().numerical().Create("res_CTE", "Global")
Call res_CTE.set("expr", "CTE_3CSIC")
Call res_CTE.set("data", "dset1")
results_CTE=res_CTE.getData(0) <- this line doesnt work
CTE_3CSIC is the optimized parameter. I have looked up the LiveLink For Excel Users Guide as well as the COMSOL API reference but couldnt find the proper way to do this. Any help is greatly appreciated.
Hello Sotiris Thomas
