Subdividing a Boundary in COMSOL
Hi COMSOL world!
I am a newbee and I tried looking in the Forums on how to subdivide an existing figure.
For example I have a circle in a simple 2D cartesian plane and would like subdivide the figure.
By default in the geometry section COMSOL subdivides a circle into 4 pieces I would like to have
12 pieces so that when the time comes to implement the boundary conditions it would be just perfect.
I also have the newest version of COMSOL 4.0a and I don't know how much it would change from other versions.
Please let me know.
I greatly appreciate your help in Advance!
Pablo
3 Replies Last Post 7 juil. 2010, 18:34 UTC−4
Posted: 1 decade ago 7 juil. 2010, 16:57 UTC−4
what you can do is to intersect your geometry with lines, then use split (if they're solid then convert them to curves first).
Posted: 1 decade ago 7 juil. 2010, 17:11 UTC−4
Daniel Tz,
Thank you very much! This is of great help!
I will try this ! Just to close this topic and for my future reference
can I assume that this process cannot be automated i.e given a circle
or any other 3D or 2D figure? I.e If I needed 100 segments I would
have to do the process you just described?
Luckily I only have to do 12 segments!
One more time , THANK YOU!!!!
Pablo
Daniel Tz, Thank you very much! This is of great help! I will try this ! Just to close this topic and for my future reference can I assume that this process cannot be automated i.e given a circle or any other 3D or 2D figure? I.e If I needed 100 segments I would have to do the process you just described? Luckily I only have to do 12 segments! One more time , THANK YOU!!!! Best regards, Pablo
Posted: 1 decade ago 7 juil. 2010, 18:34 UTC−4
If you are using v4, you can actually define curves. So, I can draw a circle with as many segments as I like. Try drawing 3 point curves to see what I mean.
