30 juin 2010, 01:35 UTC−4
If you are talking abouit the position of a "max" or "min" value, I believe in 3.5a we do not get any other feedback than the "point" shown on the graph. You must use matlab, I beleive, to extract it's location.
In V4 you have operators, but I do not believe they give you the poition.
but on the other hand, COMSOL is a math tool, you can define the average radius as a variable, then have COMSOL to derive it and find the zero that should give you the location, no ?
30 juin 2010, 03:25 UTC−4
Actually my problem is a bit simpler : I don't want to find a max or min position, I'm interested in exporting the radius in a specific spot, but I don't know how to tell Comsol to do that.
Thanks for the reply anyway
30 juin 2010, 15:41 UTC−4
Well the radius is linked to the second derivative (locally) or you can, for a cylinder calculate the average radius by integrating over a loop.
Something like, if the cylinder axis is along Z, you define the variable
Rxy=sqrt(x^2+y^2)
and
Rxuyv=sqrt((x+u)^2+(y+v)^2)
and integrate these for different heights Z.
To define the loop Z height, either you split up your volume/domain to have edges to integrate along, or I believe (would have to try/check) that in V4 you can define split surfaces and integrate along these border.
test it carefully first, these are ideas I come to, as first thoughts, to be verified.
good luck
Rxy=sqrt(x^2+y^2)
and
good luck
1 juil. 2010, 06:18 UTC−4
Thanks for the answer.
I've managed to get what I wanted, here is how I did it :
Using the *Integration Coupling Variables > Boundary Variables* under the *Options* menu, I got back the radius change, integrating the following expression over the top side of the cylinder :
dR = -d(uaxi_smaxi,r)
Thus I have the radius over time by subtracting dR to my initial radius.
I've set up a Point variable integration too, in order to have the variation of height over time, by defining :
dH = -w
on one of the top corners of my cylinder (which is a square, given the model is in a 2-D, axial-symmetric mode).
And thus I can have the height over time by subtracting dH to the initial height.
I've a couple more variables defined, for various needs, and it seems to work pretty well.
Thanks for your interest in this matter Ivar, it was much appreciated.
Y.
dH = -w
Y.
