Why do I get "Error 9171"
Is there an issue with using constants, defined in the Constants window, to define geometries?
I have defined a number of constants that I want to use as geometric parameters, but I get a syntax error when inputing the constant names into the geometry dimension fields:
Error: 9171
Syntax error in expression
- Expression: 50 [mm]
What is the cause of this?
Thank You,
Jonathan
2 Replies Last Post 21 juin 2010, 16:30 UTC−4
Posted: 1 decade ago 21 juin 2010, 13:39 UTC−4
if you are in 3.5 I seem to remember that the units are not accepted for dimension of geometries, its better in V4
Try with 0.050
Hi if you are in 3.5 I seem to remember that the units are not accepted for dimension of geometries, its better in V4 Try with 0.050 Good luck Ivar
Posted: 1 decade ago 21 juin 2010, 16:30 UTC−4
Ivar,
Thank you for your help!
Ivar, Thank you for your help!
