10 years ago
15 mars 2015, 05:41 UTC−4
There are so may types of snow with varying crystal size, moisture and density. I would use properties of ice the properties of which you can google. Snow is "porous ice" with pores filled with water or air.
Interesting question, though :)
br
Lasse
br
Lasse
Edgar J. Kaiser
Certified Consultant
10 years ago
15 mars 2015, 06:36 UTC−4
'Porous ice' may be a useful approximation for electromagnetic properties but probably not for acoustic properties.
There is some literature on the topic, e.g.
arxiv.org/abs/1502.01284 and
eprints.lib.hokudai.ac.jp/dspace/bitstream/2115/20232/1/A20_p23-63.pdf
I am sure you can find a lot more. The last resort is certainly to measure the properties you need in snow samples.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
There is some literature on the topic, e.g. http://arxiv.org/abs/1502.01284 and http://eprints.lib.hokudai.ac.jp/dspace/bitstream/2115/20232/1/A20_p23-63.pdf
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
