Luke Gritter
Certified Consultant
9 years ago
13 mars 2015, 14:20 UTC−4
Syed,
The "node names" simply specify how the different circuit components connect together. For example, a simple RC circuit connected to a plasma could look like the following:
Ground: 0
Voltage Source: p: 1; n: 0
Resistor: p: 1; n: 2
Capacitor: p: 2; n: 0
External U Vs. I: p:2; n:0
Node 0 is ground, node 1 is the junction between the voltage source and resistor, and node 2 is the junction between the resistor, the shunting capacitor, and the biased electrode in the plasma. The user-specified current for the "External U Vs. I" would be the plasma current at the electrode (calculated by integrating the electron current, ion current, and displacement current), and the voltage specified at the electrode would be set to the voltage at node 2 in the circuit (e.g. cir.UvsI1_v).
Luke Gritter
AltaSim Technologies
Syed,
Ground: 0
Luke Gritter
9 years ago
23 mai 2015, 09:13 UTC−4
Dear Luke ;
I am trying to model a simple electric circuit using .CIR interface. My circuit contains a capacitor (2.5mF) with an initial voltage (1400V) linked in series with a resistance, inductance (10mOhm, 2uH respectively ) and External I Vs. U to feed a single turn coil in mf .
everything goes great until i add a diode in series to the circuit ! it gives " Failed to find consistent initial values " .
i tried to flip the capacitor order (0,1) it works but it gives a wrong results !
any explanation ?
Best Regards ;
Dear Luke ;
any explanation ?
Best Regards ;
