Repeated error test failures. May have reached a singularity. Last time step is not converged.
Hello
I am repeatedly getting the above mentioned error, no matter how I change the set of initial values and the boundary conditions. I am making my sample model in 2-D, a time dependent study using Conjugate Heat Transfer module. Can anyone spot the glitch here and help me out, kindly?
3 Replies Last Post 31 déc. 2016, 14:57 UTC−5
Hello Pradeep
Posted: 9 years ago 22 juil. 2015, 20:42 UTC−4
Hi Pradeep,
I have got the same error, do you solve it and could you please tell me that? Thanks in advance.
Hi Pradeep, I have got the same error, do you solve it and could you please tell me that? Thanks in advance.
Posted: 9 years ago 23 août 2015, 23:55 UTC−4
i have got the same error.could you give me a tip?thank you very much
Posted: 8 years ago 31 déc. 2016, 14:57 UTC−5
I was also having this kind of errors. In cases I was able to fix this by decreasing the Relative tolerance from 0.01 to 0.001. This way you solver will be more stable and won't blow up easily.
Akim
Hello, I was also having this kind of errors. In cases I was able to fix this by decreasing the Relative tolerance from 0.01 to 0.001. This way you solver will be more stable and won't blow up easily. Akim
