Heat convection in an Darcy porous media
hi everyone. I'm using comsol 5.0 with the "darcy law" module and the "heat transfer in a porous media" module. My current aim is to simulate heat convection into a carbonate layer filled with water. This is the first time I use comsol so I'm not very prectised with it. This is my set up:
Geometry: simple 2D square
Darcy: fluid and matrix properties with material data, no flux on the sides and no pressure.
Heat Transfer in a porous media: fluid and matrix properties with material data (I selected the darcy law flow field), a certain initial temperature and a different temperature for each square side.
The study is stationary.
The results show no flow at all into my box, as if the temperature doesn't affect water's density. Why do this occours? I have to link somehow density and temperature? I suppose something lacks in my darcy settings.
0 Replies Last Post 25 févr. 2015, 11:01 UTC−5
Hello Bastiano Deschmann
