Cluster computing error
Hello all,
I'm trying to run a model on a HPC cluster, but I am having some problems which I cannot find a solution to.
I've started by running a simple enough model, which I know runs correctly as I have run the file on my computer. Its 3d, and uses the wave optics package in Comsol 4.4. When I try to run it as a cluster job however, it never gets past about 50% before the process ends.
"Application terminated with the exit string" appears in the error dialogue, but other than that, I don't understand what the problem is.
I've ran 2d models with no problems on the cluster.
Any ideas on how to fix this? I can upload the model file if needed.
Mark.
0 Replies Last Post 18 févr. 2015, 02:22 UTC−5
Hello Mark Daly
