How to access materials property variable using material switch node
Hello all.
I want to access materials property variable(Cp,rho etc) in physics node.
When I use (nomal) material node, I can access this syntax : "comp1.mat1.def.Cp" .
Then, how should I access these variables when I use "switch for materials" node?
Ofcourse I can access each materials property in "switch for materials" node lile "comp1.sw1.mat1.def.Cp" ,
but I want to access mat1.Cp and mat2.Cp uniformly even if materials was switched.
node structure is lile this.
Materials
L sw1
...L mat1
......L def
.........L Cp
...L mat2
......L def
.........L Cp
Best regards
Hiroshi Yamashita
2 Replies Last Post 16 févr. 2015, 00:00 UTC−5
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 12 févr. 2015, 07:54 UTC−5
I think that material.rho, for example, is what you are looking for. That set of variables (material.<property>) represents the current values of rho and other material properties for the active materials in the geometry.
Magnus Ringh, COMSOL
Hello, I think that material.rho, for example, is what you are looking for. That set of variables (material.) represents the current values of rho and other material properties for the active materials in the geometry. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 16 févr. 2015, 00:00 UTC−5
Thank you, Magnus Ringh, I was able to almost resolve by this way.
I was able to get materials property in "Output properties", but I havn't been able to get in "Local properties" yet.
These variables cannot get by using material.<variable> ?
Hiroshi Yamashita
Thank you, Magnus Ringh, I was able to almost resolve by this way. I was able to get materials property in "Output properties", but I havn't been able to get in "Local properties" yet. These variables cannot get by using material. ? Best regards, Hiroshi Yamashita
