Can not open Comsol with "An unexpected error occurred"
hi everyone
Yesterday, I used Comsol normally, but today I can not open it anymore. It gives me this error and its details:
"An unexpected error occurred."
'.', hexadecimal value 0x00, is an invalid character.
at System.Xml.XmlEncodedRawTextWriter.InvalidXmlChar(Int32 ch, Char* pDst, Boolean entitize)
at System.Xml.XmlEncodedRawTextWriter.WriteElementTextBlock(Char* pSrc, Char* pSrcEnd)
at System.Xml.XmlEncodedRawTextWriter.WriteString(String text)
at System.Xml.XmlWellFormedWriter.WriteString(String text)
at System.Xml.Linq.ElementWriter.WriteElement(XElement e)
at System.Xml.Linq.XElement.WriteTo(XmlWriter writer)
at System.Xml.Linq.XNode.GetXmlString(SaveOptions o)
at Comsol.Command.BridgeCommand.ToCommandString()
at Comsol.Communication.ChannelBasedCommandManager.SendCommand(OutgoingCommandHandler commandHandler)
at Comsol.Communication.BridgeCommandManager.OutgoingCommandHandler.Run()
at Comsol.Communication.BridgeCommandManager.RunAndWait(BridgeCommand command)
at ComsolDesktop.MainWindow.StartJava(Boolean debug, Boolean devPlugins, NDisconnectInfo disconnectInfo, IBridgeCommandManager oldMgr)
at ComsolDesktop.MainWindow.StartJava(Boolean debug, Boolean devPlugins)
at ComsolDesktop.App.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
is there anyone has some ideas about this problem ?
Many thanks
Duc
12 Replies Last Post 29 août 2017, 14:23 UTC−4
Posted: 10 years ago 17 févr. 2015, 07:11 UTC−5
I have the same problem, comsol worked just fine one minute ago and now this.
Posted: 10 years ago 17 févr. 2015, 08:52 UTC−5
Hi Hugo
I have just reinstalled my Win and then the Comsol. Now, it works well. :D
Hi Hugo I have just reinstalled my Win and then the Comsol. Now, it works well. :D
Posted: 10 years ago 24 avr. 2015, 03:16 UTC−4
Re installing windows is the only option left. Do you know any other way?? Please help....
Posted: 10 years ago 24 avr. 2015, 04:15 UTC−4
Sorry ...
I did not have.
Sorry ... I did not have.
Posted: 10 years ago 25 mai 2015, 13:10 UTC−4
br.comsol.com/support/knowledgebase/1177/
Solution
This issue has so far only been observed on Windows installations. The solution is to ask the to rename/remove the vXX folder located at
C:\Users\%USERNAME%\.comsol\vXX
where %USERNAME% is the user name of the user and XX is the version you are using (44 or 50). If you have important settings in your vXX folder, it is recommended to rename it rather than removing it.
https://br.comsol.com/support/knowledgebase/1177/ Solution This issue has so far only been observed on Windows installations. The solution is to ask the to rename/remove the vXX folder located at C:\Users\%USERNAME%\.comsol\vXX where %USERNAME% is the user name of the user and XX is the version you are using (44 or 50). If you have important settings in your vXX folder, it is recommended to rename it rather than removing it.
Posted: 9 years ago 8 mars 2016, 07:39 UTC−5
Thank you Daniel Lau. It works. Thanks for the short technique to repair it.
Posted: 8 years ago 17 août 2016, 19:28 UTC−4
Thank you! It worked perfectly here
Posted: 8 years ago 4 sept. 2016, 13:23 UTC−4
Thank you very much it works !!
Posted: 8 years ago 6 sept. 2016, 18:29 UTC−4
Thank you very much. It worked.
Posted: 8 years ago 14 nov. 2016, 04:00 UTC−5
Thank you, it works perfectly !
Posted: 8 years ago 16 févr. 2017, 05:34 UTC−5
Thank you Daniel.
This technique really works
Thank you Daniel. This technique really works
Posted: 7 years ago 29 août 2017, 14:23 UTC−4
thanks alot my problem solved
