How to modify element type in comsol 4.0?
I used weak-from PDE a lot for custom physics simulation purpose. In comsol 3.5a, you can set the element shape function type and its order or even specify discontinuous element type in 'Element' tab easily. But it seems that in the new version of comsol 4.0, there is a radical change to the user interface and modelling process, and I could'nt find the way to change these settings. Anybody out there who is using the latest version 4.0 enlightens me on how to do so?
6 Replies Last Post 8 juil. 2013, 13:47 UTC−4
Posted: 1 decade ago 24 mai 2010, 11:21 UTC−4
I'm fighting too with the weak form in V4, but I understand from the "release notes" that the Weak form is not yet fully implemented, (i.e. in 2D I cannot get it to understand that I have two dependent variables, it only shows me one field).
For the element types, I understand it's now called "discretization" , and is under the main physics tabs, but you also have the "shape functions" for some items
Hope this helps on the way
Hi I'm fighting too with the weak form in V4, but I understand from the "release notes" that the Weak form is not yet fully implemented, (i.e. in 2D I cannot get it to understand that I have two dependent variables, it only shows me one field). For the element types, I understand it's now called "discretization" , and is under the main physics tabs, but you also have the "shape functions" for some items Hope this helps on the way Ivar
Posted: 1 decade ago 24 mai 2010, 23:46 UTC−4
Yes. You can modify the element order under discretization tab. But there is simply no way of changing the order of element for each dependent variable ( such as shlag(u,2) and shlag(v,3) or shdis(w,2) ) and also changing specific element type such as bubble element (shbub) or discontinuous (shdis)element. The hermite and agris element type seems to be missing from the list. I just hope the developers do not take out this important feature that is available in previous release of COMSOL. A bit frustrarting as i could not do much work with it now as i rely a lot on weak form PDE module to do custom physics simulations.
Posted: 1 decade ago 29 juin 2010, 21:48 UTC−4
I'm having a similar problem. I'm seeing suspicious looking checkerboard patterns in a Navier-Stokes solution which I suspect to be caused by quadratic velocities *and* quadratic pressures - which violates infsup condition.
I wonder if there is some way of "tricking" COMSOL. E.g., create a physics module with order=1 pressures and force the order=2 pressures to get replaced by the order=1 values?!
[***EDIT****] Ignore at least some of the above. There is a function "shapeorder", so you can plot, say, shapeorder(u) and shapeorder(w) and see that in fact COMSOL does correctly pick shapeorder(p) to be one order lower.
I'm having a similar problem. I'm seeing suspicious looking checkerboard patterns in a Navier-Stokes solution which I suspect to be caused by quadratic velocities *and* quadratic pressures - which violates infsup condition. I wonder if there is some way of "tricking" COMSOL. E.g., create a physics module with order=1 pressures and force the order=2 pressures to get replaced by the order=1 values?! [***EDIT****] Ignore at least some of the above. There is a function "shapeorder", so you can plot, say, shapeorder(u) and shapeorder(w) and see that in fact COMSOL does correctly pick shapeorder(p) to be one order lower.
Posted: 1 decade ago 30 juin 2010, 01:48 UTC−4
I would suggest that you ask directly support
And report back here as it's of general interest for us others too ;)
Hi I would suggest that you ask directly support And report back here as it's of general interest for us others too ;) Ivar
Posted: 1 decade ago 20 mai 2011, 12:55 UTC−4
Can you tell me where I can find this "main physics tab" which should contain the "discretization" entry?
[QUOTE] Hi I'm fighting too with the weak form in V4, but I understand from the "release notes" that the Weak form is not yet fully implemented, (i.e. in 2D I cannot get it to understand that I have two dependent variables, it only shows me one field). For the element types, I understand it's now called "discretization" , and is under the main physics tabs, but you also have the "shape functions" for some items Hope this helps on the way Ivar [/QUOTE] Can you tell me where I can find this "main physics tab" which should contain the "discretization" entry?
Posted: 1 decade ago 8 juil. 2013, 13:47 UTC−4
Hi.
In COMSOL 4.3 you can change the element type by clicking on the model (model builder tree to the left). Then, under model settings you find the option "Geometry shape order". With this option you can set the element type for your entire model.
Cheers.
Hi. In COMSOL 4.3 you can change the element type by clicking on the model (model builder tree to the left). Then, under model settings you find the option "Geometry shape order". With this option you can set the element type for your entire model. Cheers.
