get the error : Duplicate parameter/variable name. - Variable: mod1.ux
Ghodsiehsadat Jahanmir
Hi all,
my computational model is composed of some sub-domains with different physics for flow. two have Darcy physics and third one uses laminar flow. in running simple steady state flow I faced this error. Can anybody help me?
- Variable: mod1.ux
Error in multiphysics compilation.
- Feature: Compile Equations: Stationary (sol1/st1)
Best
1 Reply Last Post 19 déc. 2014, 07:15 UTC−5
Posted: 1 decade ago 19 déc. 2014, 07:15 UTC−5
Check the dependent variables in each physics node. If the same name appears in two nodes, just change the name.
br
Lasse
Check the dependent variables in each physics node. If the same name appears in two nodes, just change the name. br Lasse
