[simple question] defining an integration function after solving model does not work
Hi all,
I have solved a model and I have the results. Now, I need to do some post-processing on my data. I defined an integration function in "Definitions" thread. But once I try to use it in the "Results" for plotting data for example, I get "Unknown function or operator" error. I have the same problem with any function that is defined AFTER solving step.
Is there any way to get it to work without solving the whole model again?
Thanks!
2 Replies Last Post 13 déc. 2014, 16:21 UTC−5
Posted: 1 decade ago 13 déc. 2014, 07:46 UTC−5
try to "Update Solution" (for further information have a look at the reference manual). I think this will fix your problems.
Maximilian
Hello, try to "Update Solution" (for further information have a look at the reference manual). I think this will fix your problems. Best regards, Maximilian
Posted: 1 decade ago 13 déc. 2014, 16:21 UTC−5
Thanks. Worked fine!
