Why Particle Tracing for Fluid Flow can not used in dense flow model?
It is said that particle tracing module can only be used in disperse flow, rather than dense flow. I want to know why it can not be used in dense flow? I'm trying to build a model of water migration in sand particles. Is there any other model which is suitable ?
1 Reply Last Post 22 juin 2017, 05:04 UTC−4
Hello Yuan Guo
Posted: 7 years ago 22 juin 2017, 05:04 UTC−4
Hi Yuan,
long time ago but do you found a Solution for your Problem?
Have the same Problem here.
Regards
Manuel
Hi Yuan, long time ago but do you found a Solution for your Problem? Have the same Problem here. Regards Manuel
