29 avr. 2010, 19:36 UTC−4
I have only managed to import Nastran Neutral files, as mesh cases, but I'm not sure COSMOS can generate this format (but what's wrong with a Comsol mesh ? from an Solidworks imported file)
Have fun Comsoling
Have fun Comsoling
29 avr. 2010, 20:26 UTC−4
Hi Ivar,
My problem is that the default tetrahedral mesh it creates is too much for my computer memory (4gig ram). The error is insufficient memory for LU decomposition. I have tried and failed to create brick and other elements to reduce number of elements without resorting to coarse/extra coarse mesh. Solidworks as well as Ansys seems to create nice mech with fewer brick elements.
Susant
Hi Ivar,
Susant
30 avr. 2010, 01:50 UTC−4
"tets" are the smallest ones, in the worst case you could try linear elements, take a look at
www.comsol.com/support/knowledgebase/875/
But I doubt that linear elements would help for the meshing.
Then you have only the approach of simplifying your model, using symmetry and or trying to adapt it to 2D
You know 30 years ago the ones from the east did as good if not better than the westerns with their supercomputers, because, not having that advanced CPU power they used their head and reduced analytically their problems to make them resolvable by hand or with their scarse CPU power, so I would say, take the good things from each side, try it out ;)
http://www.comsol.com/support/knowledgebase/875/
