Mikael Noerregaard Nielsen
10 years ago
24 nov. 2014, 03:44 UTC−5
Hey Jonas
A symmetry boundary condition exists in COMSOL which can be selected like any other surface boundary condition.
Just to clarify: What are you trying to model, meaning which results are you looking for?
Best regards
Mikael
Hey Jonas
Best regards
Mikael
10 years ago
24 nov. 2014, 03:54 UTC−5
Hi Jonas
What you are asking is not possible: Your input flow profile is flat, 1 m/s over the entire inlet face. Along the tube the flow profile develops, so outlet cannot be same as inlet. My suggestion is that you add another similar geometry object, and use the first one only as a flow development step, and do the rest of your simulation in the second one. In the case of a plain tube, a fully developed Poisseulle flow can be used as a BC, and then there is no more change in the flow profile within the tube.
I wish I understood your problem set-up properly.
br
Lasse
Hi Jonas
br
Lasse
10 years ago
25 nov. 2014, 02:11 UTC−5
I believe still your remark above, about the pressure drop, is correct, that is: you must ensure the pressure is not "reset" by the periodic conditions.
But I believe this is possible (I do not have access to COMSOL just now, all licences fully booked and used , it's popular here :)
In the "Equation" view you should be able to check which variables are concerned by the periodic condition, and if needed correct the equation at will. Be aware in that case you "block" e equations and COMSOL will no longer adapt the equations if you change your model, that becomes then your responsibility, a small "lock" reminds you about this in the model tree in front of the node.
On the other side you must ensure fully developed flow, as your periodic condition means you are somewhere in the "middle" of your tubing
